I had ANOTHER whistler mishap...
After melting my lens, I bought a new light and it seemed it would be smooth sailing from there, and it seemed so until this morning when I peeled the painters tape and paper away from the reflectors to view my nearly finished product and this is what I found:
As you can see, the low beam reflector's reflective paint is completely covered in cracks, and some of it flaked off. I am fed up with this supposedly easy Whistler mod project as it has been nothing but a PITA. I am probably going to buy a new drivers side light and return to stock appearance. I would love to have the Whistler look but this project has wasted my time and money.
I basically put fingers prints all over the sticky part of the tape and it worked fine. The oil from my hands kept the tape from being too sticky....
Also, some of the rectangular reflector sections on my driver's side lamp were cracking even before I took the headlight apart, so I used some chrome vinyl to fill in those areas and it looks as good as stock.
just some tips for future reference
I basically put fingers prints all over the sticky part of the tape....it worked out fine. The oil from my hands kept the tape from being too sticky....
NOTE: some of the rectangular reflector sections on my driver's side lamp were cracking even before I took the headlight apart, so I used some chrome vinyl to fill in those areas and it looks as good as stock
To the OP just return to the stock look cuz your not having luck on your side.
I got the "low adhesive" painters tape, stuck it on my jeans before applying it to the light, and even then I still had a couple small spots where it pulled off the reflective stuff
I bought this b/c it has the best mirror finish compared to other brands I have used. You would have to cut out individual pieces from the vinyl roll and "tetris" them on the reflector.. it is time consuming, but looks great when finished.
http://cgi.ebay.com/ebaymotors/24-x-...Q5fAccessories
I use this method also both are effective
I say do it anyway but be prepared. Also, make sure you sand the 'chrome' well. I had bad luck with the paint so i started over and sanded it all the way down to the plastic. Worked great after that. Oh and don't face the lens towards the heat coils in the oven or you will melt it like I did. Just take your time and be prepared if you have to shell out the cash for a new light.
How much will you be selling for if you don't mind me asking? If I ditch these lights It would be cool to buy some already made for me.
started mine last night. No problems yet, but my can of krylon fusion said to apply "multiple light coats about 1 minute apart" and so far, it looks like it came out pretty good. I think i might ad another coat or two after work today. I also really need to restore my headlights while they are drying. Masking the reflective part was easily the biggest pain in the ***.
