removing 00' Z28 headlight lens?
Is it possible to gain access to the lens area around the bulbs by separating the clear plastic cover from the reflector/bulb housing? I want to paint everything, except the reflectors of course, the same color as the body of the car.
Re: removing 00' Z28 headlight lens?
I think I have seen some one on here that has done it. Do a search see if you can find it. I tried to but when I heard a little crack I gave up. Good luck and becareful.
i would be careful when taking it apart, for only one new one, its like 300 dollars, i have replaced one, i wish they weren't so much
