Shorter Antenna
Shorter Antenna
Don't know if any of you guys have ever tried this, but I heard about it a couple weeks ago and gave it a shot... Any of yuo ever notice how our antennas look like they are off of an RC go-kart? A budy of mine talked me in to cutting it down. I figured I would give it a shot. I cut it down to 13in.. I have had no radio interferance at all. It makes it look so much better. I'm gonna try and get a pic on here sometime soon.
Re: Shorter Antenna
Our famous moderator Steve cut his antenna down, and it certainly helps out on the appearance. Make sure you put a small vacuum cap on the end so that you don't take someone's eye out.
The other choice is installing a power antenna with a bypass switch like I did.
Re: Shorter Antenna
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Xsta Z 28:
<strong>Our famous moderator Steve cut his antenna down, and it certainly helps out on the appearance. Make sure you put a small vacuum cap on the end so that you don't take someone's eye out.
The other choice is installing a power antenna with a bypass switch like I did.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Any details on how you wired that in?
Thanks!
Thanks!
Re: Shorter Antenna
actually, it didn't hurt to bad on the distance... I live near houston and i have a lake house about two hours out, and still pick up the houston stations about the same as before...
Re: Shorter Antenna
It makes it look a lot better especially when you car is lowered. I cut mine with bolt and lock cutters then gound it flat so the ball would go back on. No reception problems here either.
Re: Shorter Antenna
Why not buy an aftermarket antenna? I got mine from http://www.billetspecialties.com
Here are some links to the antennas they carry. They messure 18 1/2" in length and look great!
http://www.billetspecialties.com/ite...pid=231&rdir=1
http://www.billetspecialties.com/ite...pid=232&rdir=1
http://www.billetspecialties.com/ite...pid=233&rdir=1
Eric
Eric
Re: Shorter Antenna
We cut mine.
Here is a pic where you can sorta make it out.
http://community.webshots.com/photo/...54436149AwAEIl
Re: Shorter Antenna
Billet good <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> I've got a trenz billet antenna on my SS I think it looks good with the chrome 10 spokes I've got on my car.
Re: Shorter Antenna
The other choice is installing a power antenna with a bypass switch like I did.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yep, I did cut mine down <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> -- actually I bought another one from GM for $10 (the other type with the coiled wire) and cut it down.. sanded it down and put a small brass ball (painted) on the end.. that antenna was so popular it was stolen <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Next one same thing but just put a tiny vaccume cap on the end.. this antenna now lives on Poltergiests car <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Now I have the power antenna and I LOVE IT!! only $65 through GM parts direct and it was a snap to install <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Here is a website I used for install tips:
http://www.blackcamaro.com./antenna.htm
Have fun <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Re: Shorter Antenna
I also have the power antenna with a bypass switch. When I installed it (first got the car), I got a second fog light switch, painted it black (so it didn't have the light symble on it), and the put it inline to the lead running to the antenna.
Later I installed my amps so I spliced into the lead before the switch so I could still have the amp turn on with the antenna down. Its sweet...I go 99% of the time with the antenna down (CDs...) but then just hit the switch and I have perfect reception.
The camaros don't have the lead (a wire) from the factory <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> but the radio (and the plug) do have the location for it. Just look on the back and you will see an empty slot. Just take some wire and bundle it up tight so it will force into the slot and that will do it.
