Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro 1990 to 2002 How to Replace Parking Lights<br>Step by step instructions for do-it-yourself repairs.
Official 4th Gen F-Body Light Bulb List
How do I get the light put of the socket for the automatic transmission shift plate. I have the socket out of the player just can't get the dang bulb out of the socket.
im having an issue finding the right bulb on the site for the map lights. whats the exact PN? i want bright as hell white leds lol. my cluster is great after the LED upgrade and id like to do the map lights as well
#33
Not to revive an old thread but i found a really easy method to removing the bulbs from the rear view mirror:
First remove mirror from mount and unhook connection cable.
Using a flat head remove the light lens. And the best advice and the easy method for removing that bulb, just take the same flat head and put it under the bulbs edge of the metal cylinder end and lift. It will pop out of the metal clip, repeat for the other side.
This was a nice mod because it took less than 5 minutes.
And for mhugney, just use less layers
#35
I know op aid quit quoting sylvania but sylvania says firebird trans am front blinkers is 3357a/3457a... firebird exc trans am is 3157.... Wtf is the difference
#37
No. 1156 is the round bayonet-style socket. 98-02 Firebirds come with a wedge-based 3155/3156/3157 style bulb socket for the primary brake lights and reverse lights.
3357A/3457A is a higher wattage than 3157A and will melt the plastic housings (I made this mistake once because I wanted it to be brighter than stock 3157 but didn't think about the increased heat output of a higher wattage bulb). DO NOT USE THEM!!!!
Also, 3157 is a yellow bulb. 3157NA is the amber bulb.
3157NA is an Amber 3157. If it was not orange-coated to produce an amber light color, then you purchased a regular 3157 or they labeled the package wrong. The bulb in the list for an '02 Trans Am is 3157NA, so... Yeah.
#39
this is an awesome write up and very helpful! thanks!
only thing I cant find is the same billscamaros couldn't.. whats the bulb for the headlight/dimmer switch to the left of the steering wheel? anyone know?
