cowl hood engine bay temps
UNDER PRESSURE MOD
Well, I would guess that it would depend on how much heat is being generated, whether it's a NA setup vs. supercharged vs. turbo charged being least to most heat generated.
I would guess that it also depends on the color of the hood as well.
If I had to put a number range on it, I'd say it would drop temps rougly 20-30 degrees.
When I was shopping around for my aftermarket hood I did some research on this, and from what I found is that openings in the hood are designed to flow cool air into the engine bay while extracting hot air that is currently in the engine bay.
