Clear Corners + Side Marker Combo??
Street Tune (Ebay) Clear corners and side marker combo??? Anybody have them on their car and have any pictures they can post? Any comments, suggestions or reviews?? Cheap, decent? What do yall think?? I am not much of a fan of Ebay... but did not find any other sites off of Google... Anything would be appreciated! Thanks!
My buddy had a set and he did the drl mod they lasted about a 2 years now one had a condensation issue but his car is lowered and we had a monsoon last spring so it just got wet inside
here is what i did with mine
you could do something similar and just use white paint..
also if you get them run a thick bead of silicone around the outside edges so they dont fog up
i removed my drl bulb all together, and patched the back side
I just posted pics of mine under the thread "hood Scoop grill options" or something like that in this section....I have em on and think they look good. Before you put them on I would for sure water test them for leaks and silicone and needed. My drivers side gets water in it after every wash and it's a pain in the *** to take the headlight off, then take the bulb out to soak up all the water. But haven't had burning probs I have clear bulbs in there and they've been on for about 11 months now
Yea I have had them before and had the same condensation/water build up probelms... I guess if I purchase them, soaking them in water to check for leaks is a must! Super glue and silicone might just do the trick!
Is there any Performance or Aftermarket companies that make and sell a decent pair of clear corner's? Other than Ebay??
