Ls2 to t56 trans help
please this car has been sitting for almost two years now cause I can’t get this and other life obligations.
thanks
People.......
thanks
As I mentioned in your other thread I put a Yoke in the back of the T56 and have it in 4th to be able to turn the Input Shaft of the T56 in the Clutch Splines so it goes in. Grease on the Splines helps too.
If you don't want to read what we post here trying to help you out let us know know so we stop wasting our time with someone who can't listen to people who do this **** without problems.
It's anyone's guess at this point as all I see that we're getting here is crickets
measurements and boom I’m to shallow from pressure plate to bell housing.
anyone know of a shallower throw out bearing from the stock gto one?
or anyone have a drawing for a t56 mid plate so I can make one easily
They are saying that extended Crank is in that LS2 aluminum Block? Bullshit. That's 99-00 LQ4 stuff.
What is up with that whole ring on the back of the Engine? Some kind of spacer?
I'm leaning toward you have the wrong combo of parts here and trying to piece it together that way but we apparently don't know anything here since you posted a question, got answers, and believe the first answer some desk jockey gave you over the phone. You do you tho.
All my T56 cars drove after I put them together, just sayin...
If you had McLeod's LS flywheel for long crank applications, you wouldn't have a pressure plate / slave cylinder / transmission depth issue.
So post some more pics. Preferably of the crank from the side without the flywheel attached. And of the starter to ring gear area.
Because although there's an OEM way to do what you want to do, I suspect it does not apply to the parts you have.
The GTO starter and GTO bellhousing are a matched pair. They must be used together. The bell is not to be used with any other starter.
You have some more work to do. You seem to like calling big companies and believing what they tell you. It seems you have run into hogwash already.
