Sponsored by: DashLynx
How do you remove the backseat?????
Old 03-07-2012, 10:45 AM
02 Camaro's Avatar
Default How do you remove the backseat?????
I know where all the bolts are to remove them but idk the size. The two bolts that hold the back support are impossible to get to so i was wondering if anyone knew how to get to them and what the size is?
I need help quick please!! Thanks
Old 03-07-2012, 11:57 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
One 13mm bolt per lower seat bucket and two 13mm nuts holding the seat back. You'll have to also remove the bracket for the seatbelt guide with a T30(I think).
93M6Formula's Avatar
Just take the bottom seats out first. It is only 1 13MM bolt located right in the front. Pull that out then and you will be able to clearly see the bolt for upper seat. Get a 13MM socket or wrench and take out those 2 bolts on each side. You also need a star socket for the seatbelt bracket bolts on the top of the seat.
Pretty simple...
Quick Reply: How do you remove the backseat?????
