Sponsored by: DashLynx
PRESALE: Adam's Deep Wheel Cleaner
Old 02-27-2013, 02:38 PM
Matt@adams's Avatar
Default PRESALE: Adam's Deep Wheel Cleaner
A SPECIAL PREORDER OFFER FOR OUR FORUM MEMBERS
Adam's Deep Wheel Cleaner is probably one of our most anticipated launches this year,
so we wanted to give our loyal forum customers the first chance to jump on it!
All orders that include Deep Wheel Cleaner or the New Trim & Lug Nut Brush begin shipping by Monday March 4th.
As a PreOrder Special Bonus - Use the code PRESALE1 to take 10% off your order
Plus get $5 flat rate shipping anywhere in the continental US
And orders of $50 or more will receive TWO FREE Edgeless Utility Towels!
NEW Deep Wheel Cleaner Special Introductory Price! (click the image to order)
Adam's Deep Wheel Cleaner is the ultimate way to remove stubborn brake dust and metallic contamination from your wheels. The thick formula clings to wheel surfaces and allows the european derived formula to melt away the stubborn brake dust commonly left behind by many of todays high-performance braking systems. The color changing formula lets you know its working, turning to a deep purple as it activates and does the hard work for you.
Best of all Adam's Deep Wheel Cleaner is safe for all wheel finishes. So whether you have factory clear coated wheels, aluminum, powder coat, or paint the highly effective cleaning solution will remove the stubborn brake dust, but will never harm your wheels.
With active cleaning agents and advanced surfactants the formula is perfect for cleaning away the worst, most baked on brake dust commonly found in the barrel of your wheels. Simply spray on, allow the cleaner to activate, and then agitate using one of Adam's Turbo Sticks or Wheel Woolie Wheel Cleaning tools (sold separately).
Adam's Deep Wheel Cleaner is great for more than just wheels too! Have a light colored paint job like white or silver? Then you've no doubt noticed the little orange iron particles that stick to your paint. Adam's Deep Wheel Cleaner can be sprayed on these little trouble areas and used to dissolve the iron from these surfaces as well.
Adam's Deep Wheel Cleaner is guaranteed to be the best wheel cleaner you've ever experienced!
NEW & IMPROVED TRIM & LUG NUT BRUSH (click the image to order)
Sometimes the right tool for the job makes all the difference, and this is a tool you'll need to get the job done right. Use it with soap and water to clean around badges, inside door jambs, under the hood, your lug nut holes, or even your brake calipers. It's a versatile tool backed with the Adam's 110% money back guarantee!
Our newest Trim & Lug Nut Brush uses the same super soft boars hair as our previous brush, but now set in a completely metal free design with a longer tapered handle thats more comfortable and more durable than our previous version. It works amazing with our NEW Deep Wheel Cleaner to get that hard to clean brake dust out of the hard to reach areas.
To ensure it withstands years of use with cleaning products and water the bristles are set in a completely chemical resistant epoxy, secure set in a the tapered plastic handle, the top of the brush head is then cut to a slight curve to allow easier access into tight spaces around lugs nuts and other wheel crevices.
The 7.5" long handle makes this brush extremely comfortable to work with and the 2.5" long bristles make this the ideal tool to clean away without ever scratching delicate surfaces. When its not cleaning wheels the Adam's Trim & Lug Nut Brush is the ideal way to clean around badges and emblems. Simply dunk in your wash bucket or spray a liberal amount of Detail Spray into the area to clean and gently agitate the area.
Adam's Trim & Lug Nut Brush has great uses around the interior of your car as well. Use it to clean around radio control *****, door switches, or anywhere those tiny bits of dust and crumbs want to hide. You'll find dozens of uses for this effective cleaning tool all over your car that will not only make your detailing easier and more effective, but more enjoyable too.
CHECK OUT OUR CLEANER & BURSH COMBO, DEEP CLEAN TIRE & WHEEL KIT,
or DELUXE DEEP CLEAN TIRE & WHEEL KIT FOR EVEN BIGGER SAVINGS!
For More on The NEW Deep Wheel Cleaner or NEW Trim & Lug Nut Brush watch our latest video
Old 02-27-2013, 02:40 PM
blackpala96's Avatar
thank god, these Brembos dust like a mother..
Old 02-27-2013, 03:43 PM
ezzlez28's Avatar
Got in on this. Cant wait to use it once spring finally rolls around.
Old 02-27-2013, 04:04 PM
9WhiteCamaro9's Avatar
May have to get in on this one as well... after I talk to the wife, haha.
Adam's, is this stuff safe for polished wheels?
Old 02-27-2013, 06:41 PM
US_Army_Z28's Avatar
Probly gettin in on this myself if its safe for powdercoated wheels with enamel and clear coat
Old 02-27-2013, 06:58 PM
Adam's Polishes's Avatar
Yep. It's pH neutral, not acidic.
The safety rules of any wheel cleaner still apply though; don't let it dry on the wheels and don't apply to wheels that are hot.
Old 02-27-2013, 07:00 PM
Absolutely...
Old 02-27-2013, 07:10 PM
Well then most likely tryin this out, getting ready to buy new wheels so need something that'll keep them looking new, and these hawk performance pads dust like hell
Old 02-27-2013, 07:55 PM
chadroosa's Avatar
how long will this sale last?
Old 02-27-2013, 10:00 PM
99 ss's Avatar
Is it safe to use on chrome rims
Old 02-28-2013, 02:33 AM
What about runoff onto tires? Harmful to the rubber at all?
Old 02-28-2013, 10:41 AM
I'm very confident you'll enjoy it. Keep in mind our 110% guarantee also. No skin off your back to at least give it a try.
Not exactly sure, at least through the weekend.
Absolutely. As mentioned, it's safe for all wheel finishes. Just be sure to never use it on wheels that are hot and don't allow it to dry and you'll be good to go!
Totally safe. It's pH neutral, so it's still a gentle but incredible effective cleaner.
Chemistry is neat!!!
Old 03-01-2013, 09:17 PM
TheSilverOne's Avatar
how does this compare to sonax?
Old 03-02-2013, 08:09 AM
Sonax is the industry standard when it comes to this type of product, so we certainly had our work but out for us to make a product that could compete, and compete effectively.
One big difference with our Deep Wheel Cleaner is the smell. It won't curl your nose hairs when you use it, which is always a plus.
We are also coming in at a competitive price point, especially for those who grab some during the presale that is currently underway.
As always, our products carry a 110% guarantee, so if you are unhappy with it's performance, we'll take it back without a hassle. I can confidently say though that I don't think that will be an issue with this product.
Old 03-02-2013, 08:26 AM
Rare96LT1Formula's Avatar
Good price. Might have to try some of this out once I run low on Wolfs deironizer.
Old 03-02-2013, 10:29 AM
Blackpanther99's Avatar
Ill be interested in purchasing one of these later on.
How does it work on chrome wheels?
Old 03-02-2013, 10:55 AM
mac62989's Avatar
Is it possible to just buy the cleaner without a brush or the other stuff? I can buy 3 bottles of Sonax for what one of these cost with 10% off the presale price..
Old 03-02-2013, 03:42 PM
egott_91's Avatar
Click on the image of just the deep wheel cleaner bottle. Price for that is $24.95 intro price plus 10% off, so just over $22. Not sure where you're picking up Sonax for under $8 a bottle?
Old 03-02-2013, 03:59 PM
mac62989's Avatar
Thanks, I clicked on the lug brush/cleaner combo for $40. PM sent.
Old 03-04-2013, 10:33 AM
Thanks everyone for your orders! Can't wait to hear the feedback on this one.
Quick Reply: PRESALE: Adam's Deep Wheel Cleaner
