Sponsored by: DashLynx
Corvette C6 Z06 Wheels and Nitto NT05 tires (staggered)
Old 03-03-2016, 08:38 AM
michakaveli's Avatar
Default Corvette C6 Z06 Wheels and Nitto NT05 tires (staggered)
Anyone know what size rear tire I can run without rubbing the inner wheelhouse on my '99 SS? I am looking at the 18 x 10.5 rear wheel size.
I currently have the same wheels, but the deep dish version that appears just recently became discontinued ( I wanted the 18 x 10.5 for the rear).
I'm interested in running the NT05 on the rear.... 295/35R18?
Anyone have any pictures of this setup on a pewter car they can post?
TIA
Corvette C6 Z06 Wheels - Black 18x10.5/17x9.5 SET
Old 03-03-2016, 08:57 AM
dojob's Avatar
I'm running 18x10.5 +58 with 285/35 Michelins... which is probably the fattest 285/35 you can get. I don't rub
Use this tool to compare your desired specs:
https://www.rimsntires.com/specspro.jsp
Old 03-03-2016, 09:12 AM
Thank you!
Purrrdy ride!
Old 03-03-2016, 12:04 PM
hokeplaya05's Avatar
I have 18x10.5s +50 offset Weld RTS's with 295-35 nt05's and had to massage the inner fender a bit, I still need to get the fenders rolled as well. I think depending on the offset of the wheel, a 295 is going to rub a little but on either the outer or inner fender.
Old 03-10-2016, 05:55 PM
2JAWZ's Avatar
Mine are here. Oem. Tires Friday hopefully mounted Monday
Old 03-10-2016, 06:37 PM
What size are they and offset? They look nice .. Post a pic here once mounted 😎
Old 03-10-2016, 07:19 PM
2JAWZ's Avatar
18x9.5 front +40 : 19x12 rear +53 with 275-35 and 325-30 Tires.
Old 03-10-2016, 07:47 PM
looking forward to pix.... And what mods so it doesn't rub in e rear
Old 03-15-2016, 10:44 PM
2JAWZ's Avatar
Will have better pics soon. It takes some work but is doable. Still need some finish work.
Old 03-15-2016, 11:52 PM
Neko's Avatar
Probably irrelevant, but I have 18x9.5 C5's in the back with 285/35ZR/18 Hankooks. I believe they are 56mm offset. Stock ride height, no rubbing, and I've since put about 5000 miles on them.
Old 03-19-2016, 09:58 PM
Thanks for replying
Looks legit! Post more pix when you get them
Old 03-20-2016, 08:02 AM
2JAWZ's Avatar
I posted a new thread with a couple pics.
Old 03-21-2016, 09:37 PM
james duperre's Avatar
i got a 305 on the rear, TA thou. BFH mod and bumpstop relocation. lowered with BMR springs as well. no clearance issue at all, hard to find a good sticky tire in 18" i got nitto 555
Old 03-22-2016, 03:33 AM
2JAWZ's Avatar
The NT05'S are a great dry tire to.
Quick Reply: Corvette C6 Z06 Wheels and Nitto NT05 tires (staggered)
