Trans Am LED Fog Light Install (Morimoto Knockoffs)
#81
There's no harm in giving it a shot, you'll know for sure when you go to remove them if they'll come out of the bumper hole.
If you can't get them out together, here's something to think about.. They still have better than OEM fog light replacements out there. If something was to happen, I know I can always get a set of aftermarkets and would mount the same way as these LEDs.
Looking forward to your install pics!
#82
Mike
#84
Ah...got ya. Ok. Thanks man. Hey while its on my mind....So you are looking at the fog light, which way is the top and which way is the bottom. There is the typical "DOT" writing on the lens so should that part be the top or bottom when mounted?
#85
I believe that is on the bottom. The sure fire way to tell is once old fogs are removed, plug this fog into the socket and see which way the light shines. There should be black above the cutoff and light below it.
#91
Amazon.com: GENSSI LED Auxiliary Lights Fits Harley Motorcycles (Two 4.5 Inch Auxiliary Lights, Black): Automotive
These look like the original ones, but are under the brand Genssi. I think I'm going to order them, free one-day shipping with Amazon Prime, so I'll let you all know what they look like tomorrow, lol.
Thank you for this! I drive primarily with my fogs, and these will make an great improvement.
Chris,
EDIT: Infinite, what License plate bulbs are you using? Mine LED has been getting dimmer lately.
#92
Chris,
Chris,
I made my own LED board for the license plate light. There's 96 white LEDs on it, I have a thread some where on it.
#94
Check this thread out. This might help. Looks like some new camaro fogs.
I finally got mine out of storage so installing the fogs are next on my list...ill post more pics when i get mine up.
#95
So I got them in the other day, and they are the same like the other guys received, with the longer wire pigtail in the back.
There's less heatsink material to tap into, but hopefully I will be able to make these work.
Chris,
Chris,
#100
There's several other options to chop it off. Cutoff wheel on an angle grinder, grinding wheel, hacksaw, etc.
