Avant garde wheels (bmw wheels)
So as i am looking for the Miro 111 i came across the Avant Garde M359 Wheels and fell in love with them they look so sick. Ive have been reading for hours on fitment and offsets in the sticky provided in the wheels and tires section. Forgive me for my lack of knowledge when it comes to bolt patters and offsets but in the sticky it said the bolt patters for the Trans Am's are
5 x 4.75" or 5 x 120.65 mm, and the offsets are as follows
WIDTH ..... OFFSET ......... WIDTH OF TIRE
Front and Rear
7.0" ..... +35 to +40 mm .... 215, 225, 235
7.5" ..... +35 to +45 mm .... 215, 225, 235
8.0" ..... +38 to +55 mm .... 225, 235, 245
8.5" ..... +38 to +45 mm .... 235, 245, 255
9.0" ..... +38 to +56 mm .... 255, 265, 275
9.5" ..... +38 to +56 mm .... 255, 265, 275, 285
10.0" ... +38 to +48 mm .... 265, 275, 285
REAR Only
10.0" ... +38 to +54 mm .... 275, 285, 295
10.5" ... +38 to +50 mm .... 285, 295, 305, 315
11.0" ... +45 to +56 mm .... 305, 315, 335
i want to go with a 19X9 in the front the bolt patterns are 5X120 with a 35mm offset and the rears are 19X10 bolt patters 5X120 with a 38mm offset. So my question is although the sticky says 5X120.65 mm and these wheels are 5X120 will i run into any problems getting them install and if so what modifications do i need to do, also for the fronts the offset is off by 3mm and the rears are perfect does that affect anything? I've done some research on the Miro 111 and they dont offer those exact bolt patters but do have em in the offsets provided above and people her in tech run em
Front and Rear
REAR Only
Douchebag On The Tree
I'm not great with offsets, I can never remember which way is which. However if you get the +35 fronts you might run into clearance issue since it's outside the recommended range. The wheel could either have strut rub or hit the fender (whichever way it goes).
With the bolt pattern you'll have people that will say you should just get wheels that fit 100% correctly. And going with a different bolt pattern you are taking on an inherent risk, but many many many people run them and I don't think I've ever seen anyone have issues with it. The difference in the patterns is ridiculously small.
