Sponsored by: DashLynx
Common squeeks found in the rear of the car
Old 01-01-2005, 09:36 PM
Tech's Avatar
Default Common squeeks found in the rear of the car
I've already tightened the hatch bolts and tweaked the rubber stops. It's not the rear seat brackets and I've removed the spare tire.
What are some common things that I have not listed? TIA
Old 01-01-2005, 11:52 PM
jammon46's Avatar
take off your rear sway bar and grease the bushings up. I have heard that can cause some severe squeeking.
Old 01-01-2005, 11:56 PM
Danny2tek's Avatar
Yep grease up the bushings
Old 01-02-2005, 12:41 AM
Tech's Avatar
This is definitely inside the car. Thanks for your thoughts though.
Old 01-02-2005, 12:53 AM
Danny2tek's Avatar
Maybe the speaker area? (sail panels?)
Old 01-02-2005, 12:56 AM
Tech's Avatar
Could be. There is a styrofoam piece that is located under the speaker. I'll check it tomorrow.
What else ya got?
Old 01-02-2005, 01:16 PM
jammon46's Avatar
There is nothing else in the rear of the car on the inside. Just get a can of wd-40 and go at it. It might be two plastic pieces rubing against one another. Silicone anything that might be doing that. That stuff is awesome!
Old 01-02-2005, 01:30 PM
chupr0kabra's Avatar
Spare tire and jack?
-Mike
Is the antenna loose?
-Mike
Old 01-02-2005, 03:38 PM
Viper's Avatar
My rear DeCarbon shocks made noises like that right before I replaced them, FWIW.
Old 01-02-2005, 04:21 PM
tylerdj's Avatar
you should check the side panels in the back, mine weren't tight and were rubbing causing a squeaking sound
Old 01-02-2005, 09:52 PM
dave70's Avatar
i just bought a 99SS and there was a squeak that drives me crazy you hear it while moving slow not much at highway speeds traced it down to the pass side shock never knew a shock to squeak like that the wife calls it the little bird cause thats what it sounds like a little bird chirpping lol any ideas on a good low cost shock somthing around $100 a pair?
Old 01-03-2005, 12:17 PM
jammon46's Avatar
check on ebay for some bilsteins. a pair just sold for $125 I think. I just ordered a full set of bilsteins and it cost me $314 shipped.
Quick Reply: Common squeeks found in the rear of the car
