Anyone using FRCs with an LSX manifold yet?
Well if your using the stock fuel rails you shouldn't have any problems. The only other thing that may cause a problem is the size of the runners on the LSX. But you should be able to take care of that with a dremel in a couple of minutes, just shave the part of the FRC that has the contours for the runners to match that of the LSX.
