Drilling the factory gauge cluster??
I recently bought a McCord electric cutout that comes with an LED to tell you when its opened or closed. I want to do an install that looks factory, I dont want a light on my console or in my ashtray. I had an idea to drill a hole in my gauge cluster and mount it there. It is only going to be 1/4 inch hole. I found a place that looks like it will fit in the lower righthand coner near the gas gauge. Before I pull the gauges, could I damage the cluster by drilling a hole in it? I know if I drill a circuit it will damage it but if I find a place that doesnt have a wire running trough it will it be okay? Thanks in advance for the help.
[QUOTE=CW01WS6]I recently bought a McCord electric cutout that comes with an LED to tell you when its opened or closed. I want to do an install that looks factory, I dont want a light on my console or in my ashtray.
I have the Mccord MPP2 also, if you mount your LED there, where is your switch? The LED wires are not very long, did you make them longer?
take out the skip shift light and drill a hole and put it right there, its in the bottom right corner, would be a great spot for it!! just rip the skip shift LED off the board, its simple!
