Sponsored by: DashLynx
turn siglals not working.....?
Old 03-11-2005, 12:49 PM
marlboro racer's Avatar
Default turn siglals not working.....?
i have new clear corners with new bulbs, which work perfectly (both lights on each side). tail light turn signals stay on, they dont blink when i use my turn signal (on both sides). the fronts dont blink at all. my hazzards blink in the back and do nothing in the front. anyone run across this problem before?
Old 03-11-2005, 02:03 PM
98'MidnightBlueBird''s Avatar
check your bulbs, you did something wrong reguarding them.
Old 03-11-2005, 10:39 PM
The bulbs are brand new out of the package. They work as stated above. There has to be an electrical problem such as a bad ground, fuse, or the connecter itself. I was hoping someone has tackled this problem before.
Old 03-12-2005, 02:05 AM
WICKED SS's Avatar
its a fuse and its like $20
it goes under your dash, not those little fuses that go in the driver side of your dash.
Old 03-12-2005, 07:52 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
I had a very similar experience while replacing a DRL/turn signal socket on my 'bird. I was stupid and didn't disconnect the battery. It ended up just being a 20 amp fuse out of the fuse panel in the end of the dash.
Old 03-13-2005, 02:11 AM
Can you be a little bit more specific? Part number, pics, or a how to would be very helpful.
y2k ta,
I'll see if I can track down a blown fuse tomorrow in the fuse panel.
Thanks
Old 03-13-2005, 02:47 AM
WICKED SS's Avatar
I had this same problem a few months ago and dont have any pictures or pn. Just call or go to a dealer tell them what happen and your looking for a fuse (not those little flat fuses that go in the engine bay or side of dash its square and big) to go under the dash for your turn signals.
Old 03-13-2005, 03:13 AM
02WS6Bird's Avatar
I'm thinking Fuse
Quick Reply: turn siglals not working.....?
