Guys with transam interiors in camaros post up!
I have a complete TA interior in my car. Pics in the sig. The reason for putting a TA interior into a camaro is because it looks better.
found some
http://memimage.cardomain.net/member...919_3_full.jpg
http://memimage.cardomain.net/member...919_4_full.jpg
BTW, I hated it. Seats sat WAY too high for my pleasure
Originally Posted by BrandonDrecksage
how hard would it be to put the center part of the dash for a t/a? i'd liek to do that with the circular vents and toss a gauge or two into the vents.
Originally Posted by Z95m6
It would be very time consuming. Not really difficult it just takes a while to get it all right.
like how...i just want the middle section...with the vents? has anybody else done just that? or have they done the whole dash?
I have done it. There is no "middle section" there is only the whole entire dash board. You would have to remove the top dash pad, then you'd have to remove the console, and the entire dash. Then swap in the new TA dash and a lot of time has to be spent routing the wiring harness. I also think your fog light switch is in a different location so the wiring may need to be swapped for that. Also your ac control panel is different so you'll need to swap all the controls out of your camaro panel into the TA panel. Then you'll need to put the dashboard back in. It's pretty straight forward but it took me 6 hours.
