Air/fuel gauge install
I have a 2000 camaro ss and installing a single gauge a-pillar pod with a white face autometer air/fuel gauge. Where should i run the wires is there a grommet or something to go through, where should i hookup all the wires and does anone have a recommendation.
No there is no grommet, you ar going to have to find a good way to get to the O2 sensor that the wires will still have some slack and wont get pinched. I wrapped the wiring up in the plastic wire looms.and then taped it up.
The wires will go the to O2 sensor on the driver side, sensor 1. I remember the purple wire but thats is about it, I did mine 4 years ago.
http://www.installuniversity.com/ins...sity/index.htm
I used this info to get from the cabin to the PCM. I followed the stock wiring harness from the sensor to the PCM - it is purple.
