CME questions
CME questions
I have the factory rear lip and the CME tips...
can i attatch the rear body piece myself?? how does it go on...does it use factory mounting points under the bumper?
I just havent had the time yet to go look
Thanks!
Erik
Thanks!
Erik
They should have it...or an autobody supply. SLP used two different sizes when they mounted the valances...just use the thinnest stuff you can find and be careful how you place it because, as I found out, it will show through the gap with the bumper...another tip I was given was to paint the edges of the tape before you attach the valance...this helps the tape to blend in better...
