Sponsored by: DashLynx
How do I get tar off?
Old 07-09-2006, 04:42 PM
snketr's Avatar
Default How do I get tar off?
Lately I think I'm not supposed to have a nice car. About 1-1/2 months ago I got nailed with white paint all over every panel of my car. I'm still getting that off the body. Well, this week I must have driven down a road that just got tarred b/c now my car is caked in tar. It's at least 1/2 thick behind the wheels. I scrubbed yesterday for an hour on a 6"x6" spot to get the tar off. My arms were killing me. I have tar ALL OVER the car. It's in the rims even. Think one of those porter cables with a pad will be more effective? Which one should I get? I'm not an apperance guy, I just like a clean car. This is aggrevating.
Old 07-09-2006, 04:48 PM
What's a Sticky?
97MysticZ's Avatar
There are some things at autoparts stores specifically for removing tar, but I don't know how well they work. WD-40 works really well, I've used it before. And the easiest would probably be paint thinner....
Old 07-09-2006, 04:49 PM
White 96LT1's Avatar
peanut butter
Old 07-09-2006, 04:56 PM
cputech's Avatar
Try goo-gone or WD40
Old 07-09-2006, 05:29 PM
Brian2006's Avatar
clay bar will easily take it off with some elbow grease
Old 07-09-2006, 05:36 PM
anotherreject04's Avatar
Originally Posted by White 96LT1
peanut butter
somebody said 'peanut butter' in my thread about cleaning off rubber from a burnout....are you serious about peanut butter?
Old 07-09-2006, 05:48 PM
dj2005's Avatar
Peanut butter actually works. And if you get hungry while cleaning you can eat some.
Old 07-09-2006, 06:38 PM
Tech's Avatar
The problem is you have layers of tar. You're not going to make much headroom with a claybar. I've used Acry-Solve before. I think that's how it's spelled.
Old 07-09-2006, 07:59 PM
no, peanut butter actually works. try it. you will be amazed. it does nothing to the paint. take a bottle every time i go out to the track.
Old 07-13-2006, 09:23 AM
snketr's Avatar
Well so far I've tried-
-eblow grease-works but sucks to do
-rubbing compound-useless
-WD-40-barely worked if at all
-3M adhesive remover-working really good on the non caked areas. I have to buy another bottle b/c we didn't have much at the shop.
I'm trying to find a plastic razor blade to use but people look at me like I'm a tard when I ask for one.
Old 07-13-2006, 09:38 AM
todddchi's Avatar
Yah I think most everybody missed that part about a 1/2"!
For "normal" tar, WD-40 is really the best bang for the buck. 3M specialty products always work very well but they are also rather costly.
I think you should post a picture. I've never seen 1/2" of tar build up before. You sure you were on the correct side of the construction cones .
Old 07-13-2006, 09:51 AM
snketr's Avatar
Ha, yeah I was unless all the traffic was on the wrong side and the const crew were on the wrong side also. I'll take a pic to show how thick it is in some areas.
Old 07-13-2006, 05:36 PM
AronZ28's Avatar
Gasoline works great. Goof Off(comes in a metal can) also works. These MIGHT put a VERY SLIGHT haze into your clear coat that you would need to use some compound on.
I'd stick with tar remover you get from the autoparts store though, it definetly won't mess up your paint.
Old 07-14-2006, 07:28 AM
gtarist's Avatar
They sell plastic scrapers for teflon pans. You could try some of those. Heat up the tar with a hair dryer and scrape off the big chunks.
Quick Reply: How do I get tar off?
