Sponsored by: DashLynx
how do you remove a automatic shifter
Old 01-06-2007, 02:52 PM
barthowell's Avatar
Default how do you remove a automatic shifter
i am redoing the interior of my 98. the only problem is i can't get the shift **** off of my a4. i know in my t56 the **** just screws off. is it the same for the a4. i tried gorrilla gripping it but to no avail, and before i really go to town on it i was wandering if there are some of you a4 guys out there that know a secret about getting it off.
Old 01-06-2007, 02:54 PM
Loochy88's Avatar
put on the parking break and slide the gear lever towards you and look at the front side. you will see a small piece of metal. pull it out. its the clip that holds the **** on.
Old 01-06-2007, 03:21 PM
StrobinSS's Avatar
get a small flathead screwdriver to pry it out then use your hand if you can or pliers to pull the rest of it out and the shifter **** should pull straight up.
Old 01-06-2007, 04:53 PM
barthowell's Avatar
thanks guys
Old 01-06-2007, 05:08 PM
01ls1lover's Avatar
BFH mod usually does the trick for any problem
