98-02 Camaro Ground Effects (OEM) questions!
You should be able to get them from any gm dealer, but you'll most likely have to buy them by the piece. I think you can also get them from year one. Your best bet is finding some used. You'll come out a whole lot better in the financial dept. I think Year One wants about 1200 plus shipping, and I think retail on them, or gm parts direct will be 1500-1700 bucks plus. You'll also need the little brackets that go around the car. Like I said, your best bet is finding some used. A lot of people don't care for them and take them off. My car had them from the factory, and the p.o. sold them. I picked up a used set in good condition with all the brackets off a local guy for 150 dollars. My car still has all the brackets attached, and putting the gfx back on is easier to me than going through the work of welding up the holes, grinding the welds, glazing the holes, sanding the glaze, then priming and painting. I'd rather fix and repaint the used gfx and throw them on. I kinda like em anyway.
