odometer stop working
Old 03-14-2007, 08:01 PM
98MNBZ28's Avatar
Default odometer stop working
my odometer stop working,everything else in the gauge cluster works but that doesn't,ifi get a used one will it show my mileage or the mileage from the car it came from
Old 03-14-2007, 08:13 PM
SLVR_99-Z's Avatar
Well if the car is a 98 then i think it is stored in the cluster itself so you would need to get it reprogramed.
What is wrong with the odometer? did the display go out or did it stop counting or something like that?
Old 03-14-2007, 08:18 PM
98MNBZ28's Avatar
the display went out
Old 03-15-2007, 12:00 AM
faster_n_you98's Avatar
isnt there a bulb to replace? i dont think it went bad.
Old 03-15-2007, 01:24 AM
Brian2006's Avatar
this is a bad thing? Hell I wish my odometer went out!
Old 03-15-2007, 01:46 AM
SmokeySS's Avatar
Yeah, lmao - exactly what I was thinking.
Old 03-15-2007, 02:52 AM
dopy's Avatar
frozen in time isn't a bad thing
Old 03-15-2007, 02:54 AM
blown 346's Avatar
Your cluster is junk, You can get either a new one or a used one. But either of them would be re programmed to the current mileage of your car.
Old 03-15-2007, 10:22 PM
Copy & Paste Moderator
VIP1's Avatar
LS1Tech 20 Year Member
Its probably just a burnt out bulb.
Old 03-15-2007, 11:28 PM
1meantransam's Avatar
so the new one would automaticly reprogram to the car?
Old 03-15-2007, 11:45 PM
sapper_daddy's Avatar
my understanding is that no it wouldn't, it would show what came out of the old car but I think it will throw a code, but I know it is detected at the dealershit
'Trust''s Avatar
Are you saying they would need to be, or they will automatically? If the latter, then no, mileage is stored in the cluster.
Old 03-16-2007, 02:18 AM
blown 346's Avatar
The mileage of a used cluster would show, say the cluster has 3,000 miles on it, the cluster will show 3,000 miles. The cluster would have to be re programmed to show the actual mileage of the car.
Old 03-16-2007, 07:16 PM
98MNBZ28's Avatar
i guess i should check the bulb and if that ain't prob,then replace it?
Old 03-17-2007, 03:08 AM
blown 346's Avatar
I dont believe there is a bulb you can replace for the odometer. It is built into the cluster.
Old 03-17-2007, 10:50 PM
VIP1's Avatar
Others have changed its color. It may not be easy to replace, but its replaceable,
Old 03-17-2007, 11:04 PM
ghardester's Avatar
LS1Tech 10 Year
You need a new instrament cluster. It's one unit and when one thing goes out the only way to fix it is to replace the entire cluster. It's the new 'plug and play' type of auto repair. 2 out of my 4 Pontiacs have needed it done. There are no user accessable bulbs to replace.
Old 03-18-2007, 12:03 AM
VIP1's Avatar
Then how are so many people doing it?
Old 03-18-2007, 05:20 AM
Reject's Avatar
theres a bulb there, i cant remember who did it, i think it's in teh sticky up top. but he changed it to blue
edit
i'm so good it hurts
https://ls1tech.com/forums/appearance-detailing/436902-t-blue-odometer.html
Old 03-18-2007, 08:55 AM
Duffster's Avatar
it's not 1 bulb, it's 3 LEDs. All 3 LEDs going out at once is like 1 in a quad-megazointillion. Chances are its simply the cluster as most the discussion is going.
Quick Reply: odometer stop working
