What LEDs to buy for ASR/Foglight/Headlight knob?
What LEDs to buy for ASR/Foglight/Headlight ****?
From what I've gathered, these are the ones that you have to solder yourself. I ordered (3) 5mm red 25,000 MCD LEDs from ledgauges.com, and I'm assuming I made the right choice. Is this going to work or did I get the wrong ones? Someone posted in another thread that on keliente's install site they were using 5mm flat-tipped LEDs for these switches which is the reason I went with the 5mm.
Originally Posted by BIG_MIKE2005
PM LS1_SS, he is a sponsor & sells kits.
Cool, thanks GUZ. If I have problems come install time I'll hit ya up if you don't mind.
25000 mcd will be blinding for those switches. I use 7000 and it's bright enough as it is. In fact it lights up a little bit of the backseat. I'd be curious to see how bright 25000mcd would be
