SS grille on hood, how to remove?
Old 06-30-2007, 02:51 AM
ultraz's Avatar
Default SS grille on hood, how to remove?
Is there anyway to remove the grill on an SS hood without ruining it?
Old 06-30-2007, 07:24 AM
WayneSS01's Avatar
I have done it many times over the years to put some back-to-black on it. I take a twist tie and loop it through to form a handle. Then take a flat jeweler's screwdriver to lift up on a couple of the tabs and pull the grille out.
Old 06-30-2007, 08:17 AM
smg267's Avatar
LS1Tech 10 Year
I used a regular peice of wire and wound it though a couple holes near the corner and used a little bit of muscle. Once you get one of the corners started it pops right out.
Old 06-30-2007, 02:36 PM
nifty97z's Avatar
That is a good "FYI/DIY"
Quick Reply: SS grille on hood, how to remove?
