does anyone know how to make stock looking projectors
does anyone know how to make projectors, that look stock, you know, inside a normal housing like the ones below. except for the 98 and up firebirds
either that or if someone sells them for the 98 and up firebirds.
http://cgi.ebay.com/ebaymotors/77-82...ayphotohosting
Copy & Paste Moderator
Look in the "Lighting FAQ".
Its in the "Hall of Fame" sticky and in my sig.
Here is a link for convenience:
https://ls1tech.com/forums/appearance-detailing/710357-lighting-faq.html
The only setups that I've been able to find are custom. Take a look at that FAQ and you'll see some setups that require less modification than others.
Here is what mine looks like:
https://ls1tech.com/forums/showpost....91&postcount=6
Here is SCRWS6's setup:
https://ls1tech.com/forums/appearance-detailing/746505-trans-am-firebird-lexan-projector-adapters-no-56k.html
You'll find more like those in the Lighting FAQ. Unfortunately, there isn't anything that is plug-and-play. If you find anything, let me know and I'll add it to the FAQ.
Those ebay ones will not fit 1998-2002 Firebird and they aren't real projectors anyway. They are just a crappy housing with a hunk of glass in front of the bulb. If I remember correctly, there isn't even a cut-off shield on them.
There was a thread a while back talking about actual projector retrofit housings. Unfortunately, they were not in the 1998-2002 Firebird size and they were $1000 for a pair.
I found the thread to which I referred in my previous post:
https://ls1tech.com/forums/appearance-detailing/620634-firebird-projector-headlights.html
lol i know the ebay ones arent worth ****, i was just using them as an example to show the projector inside the housing instead of out front like that. the thread you posted last was exactly what im looking for, but sadly, it wont fit my car lol thx for your help though
