Sponsored by: DashLynx
tinit removal
Old 02-07-2008, 10:47 AM
ls1ssws6's Avatar
Default tinit removal
ok so the car has 35% now but im droppin it to 5%...what is the easiest,cleanest,safest way to remove old tint? anyone done this could give me some pointers?
thanks
Old 02-07-2008, 11:50 AM
CALL911's Avatar
Window tint is just a film. Start at a corner, or a not so long edge, and just peel it off. You may need a razor blade to initially get under neath the tint, but once you start peeling, it should come off without too much trouble. It also would help if it were in a cool humid atmosphere, instead of baking in the sun in the middle of Nevada.
Old 02-07-2008, 01:15 PM
ls1ssws6's Avatar
i know its a film, and i thought thatd be the easy part, a few people said the glue underneath is a pain in the ***...what is best for that?
Old 02-07-2008, 03:44 PM
SSlow1's Avatar
Just Windex and a razorblade for the glue
Old 02-07-2008, 04:37 PM
CALL911's Avatar
Not sure what is best, as I have peeled off tint before, and it just peels right off with little to no residue. This was a long time ago though so perhaps the glue or adhesive they use now a days takes a bit more work, but I doubt it.
Old 02-07-2008, 05:05 PM
RareBreed0295's Avatar
Heating it up a bit helped on mine.
Old 02-07-2008, 09:12 PM
EATSGTS's Avatar
i had 15% i got a ticket for it, $130 in AL. i went to 35%. i bought some stuff at wal-mart called tint-off i think. you spray it on and let it set like 15 mins it loosens it up pretty good. i used e blade on the tough places.
Old 02-07-2008, 09:33 PM
jsteele90's Avatar
when they remoed mine the women used just a razorblade and a spray bottle of dawn soap and water. done with both windows in like 8 minutes.
Old 02-07-2008, 10:20 PM
94TRANS's Avatar
a steamer works good, but you have to be careful with blades on the defrost lines.
Old 02-07-2008, 11:46 PM
multiplicityZ's Avatar
just like what everyone else said, just peel off the film, and a razorblade w/ water or windex to get what little residue is left.
the only time it is a pain in the butt is when the tint is so old that it has turned purple and it comes off in tiny little pieces.
good luck
Old 02-08-2008, 04:40 PM
SouthBLVD's Avatar
i just got mine tinted a couple of weeks ago 5%. the guy that did it said to make sure to use window cleaner that is amonia free. he said amonia is what he uses to get old tint off. he's been doing tint for years, so maybe amonia would help you get the old tint off.
Old 02-09-2008, 09:17 PM
Alt
Alt's Avatar
Or just take it to a place that does tint and they'll take care of it for you. I wouldn't do 5% tint on my own as it shows anything and everything that is between the window and the tint.
Quick Reply: tinit removal
