Sponsored by: DashLynx
Cleanning t top bar????
Old 09-23-2008, 12:09 AM
therobman's Avatar
Default Cleanning t top bar????
how the hell do you shine up the black bar in between the t tops mine looks like total *** and kills me everytime i look at the car
Old 09-23-2008, 12:24 AM
ZexGX's Avatar
Well, I don't have t-tops and have never looked closely at that piece, but I'm willing to say "polish and wax".
Old 09-23-2008, 03:05 AM
CranMaro99's Avatar
I noticed this a tiny bit too on my bar. It looks like a piece of black metal that is not painted, and looks like what stainless steel headers look like after years of use (have a rainbow-ish tint to it)
Old 09-23-2008, 11:50 AM
sdm1234's Avatar
Off the top of my head, i think it may just be a piece of black plastic between the tops. I may be wrong, though. In any case, try a deoxider (typical stage 1 Meguiars/Mothers) to clean up the surface contaminants, then a polish to richen the color back. If that doesn't work, then you may have to use a mild abrasive product to start anew.
Old 09-23-2008, 01:02 PM
1995blacktattop's Avatar
its VERY easy to remove.. i took mine off a few years ago and replaced it (the back piece broke off and i lost it) and the one i replaced it with is now starting to look faded too, i thought about taking it off and painting it..
if you remove the t-tops you'll see 4 or 5 screws on each side, all you have to do is remove those screws and then pull the thing off (it might be a little snug since i think it's attached with dbl sided tape) and it will come right off.. i didnt retape mine when i put the newer one on since the top of the roof was still somewhat sticky there, i'm guessing you could probably paint it.
Old 09-24-2008, 09:20 AM
FLA02TA's Avatar
I sanded mine down to a fine grit and then polished. Only held up for about a year though. About to do it again.
Old 09-24-2008, 10:02 AM
ZexGX's Avatar
If it's textured plastic, try using peanut butter on it.
If it's hard, smooth plastic (like the taillights), try wetsanding with 2000, then/or hit it with some good plastic polish.
If it's painted, then try a good deoxidizer like was previously mentioned, or if you can't get that, use some rubbing compound, then hit it with polishing compound (you can get both at WalMart), then some wax.
If it's painted and just AWFUL, you can sand and paint it black... It'd be best to prep it right, then clearcoat it so you can wax.
I don't have t-tops, but I do know how to shine up a car half-way decent.
Old 09-24-2008, 02:24 PM
slow's Avatar
it looks like anodized aluminum, not painted.
Ryan
Old 09-24-2008, 02:29 PM
Pipelayaz's Avatar
On my old T/A mine looked all jacked up and discolored. I waxed mine and it looked brand new with a deep black glossy finish.
Old 09-24-2008, 04:46 PM
Lotus289's Avatar
It's painted metal. Based on the weight and sound of it, it's not aluminum. I'd suggest sanding, wet sanding, and polishing first. If that doesn't get the luster back, sand the black off, prime it, paint it, clear it, buff it, polish it, re-install it.
Old 09-24-2008, 08:51 PM
1998Z28LOADED's Avatar
Dude, forget all the bs.... scuff it with steel wool and tape & rattle can. You dont even have to remove it. I did mine ( it was brown ) used black high temp paint I had and clear. Made a HUGE difference! Could never guess it was rattle canned!
Old 09-24-2008, 08:57 PM
Z28Red01's Avatar
yeah mine was bad, car only had 33xxx miles on it at the time. I just did a medium scratch/oxi remover, light scatch removal and swirl, then just polished the whole car with M3 system and finished up next day with Mothers Carnauba wax. Looks like the rest of the car.
Not into spray can painting my cars.
Old 09-25-2008, 01:49 AM
ZexGX's Avatar
So it IS just another painted piece of the car, like the little black triangles behind the windows that so many people don't think they can polish/wax. That's sad.
Another piece you can wax is the side moldings that everybody takes off. Mine were looking dirty so I hand-buffed some wax on there and BAM! the dirt came right off.
Old 09-25-2008, 04:19 PM
Z28Red01's Avatar
yup i was and polish the triangles too. You can see your reflection in um with the stock paint. I've seen some really beat up ones before that look like so bad they look like old plastic.
Old 09-25-2008, 06:02 PM
EvilBLK02TA's Avatar
well i was gonna say polish it but then I kept reading......
Old 09-25-2008, 07:44 PM
wannafbody's Avatar
I've seen plastic polish recommended. The repaint sounds good too.
Old 09-26-2008, 06:30 PM
kevinclark09's Avatar
ive tried the peanut butter thing and ive tried mothers back to black and none of them work
