Transmission acting strange
I was on the freeway and punched it in 3rd and on the 2-3 shift I hit the rev limiter.
I then let out switched to over drive and it didn't do it. Is there a reason for this. My car has never been tuned and I have stock gears.
I tried a search but didn't really find an answer. It has only did this a couple of times
LS1Tech Sponsor
well there is a difference between the 2-3 shift in 3rd and the 2-3 shift in the OD position . The Overun clutch comes on during the 2-3 shift in the 3rd position this may due to additional fluid ussage cause a slightly longer time required to make the 2-3 shift than it does in the OD position , If your shift points are already very close to the limiter this small amount of time could push it to the limiter
__________________
