Will this cooler be enough to run standalone?
After four blown up transmissions I'm sure I'll never get the stock cooler cleaned out. So tell me, will this be enough to run it stand alone? I've got one of Frank's performabuilt level2 trans and one of his 9" stalls. The car is nothing special.
http://store.summitracing.com/partde...part=BMM-70274
it's 29000 BTU unit.
Yeah it did come with one. Frank and I decided that it'd be best not to use the stock cooler and the one he sent wasn't big enough to go solo down in Atlanta. It gets too hot.
I don't have anything else mounted in the usual cooler spot so I guess I have room. It's about as big as the one he sent, just this one is thicker and double the BTU.
Just wanted some other opinions.
