tci flywheel yank converter
From what I remember reading, the bolts Yank supplies with their converters might be too short with the TCI flexplate..so might not have many threads holding it on...
Are you running the 4L60E, or did you swap to a turbo 350/400? If it's the stock 4L60 and you upgraded the flex-plate for durability, then you should be fine. The Yank converter would have the LS1 pilot. If you swapped to the 350/400 then it could be a problem. If you told Yank it was going in a LS1, then they probably built it for the LS Motor. The pilot needs to be about 1/4" longer. If you don't have any vibrations, it is probably OK, but it could also just barley be in the crank and cause problems in the future.
Chris
Chris
