does any one make a barbed trans line fitting 4l60e
does any one make a barbed fitting that threads into the side of the case of the 2003 4l60e for cooler lines. i searched and couldnt find it. thank you
Moderator
Dunno, but I have occasionally "barbed" hard
line stubs by running a tubing cutter around
a few times, making a series of ring grooves
to make the soft line "dig in". I'm sure it's a
bad, bad thing but the lines don't slip off unlike
smooth tube.
I do think you'd be better off with as much hard
line and as little soft, as you can manage.
smooth tube.
you might be able to screw in a couple fittings in place of yours from a turbo 400, should be the same STRAIGHT thread-then you could prob find a barb'ed fitting that would have a flare fitting on the other end-pretty sure they make them
or if you wanted to use AN fittings, ATI Perf Prods has the proper ones, 1/4-18 straight to #6 or #8
