A4 swap checklist
A4 swap checklist
Hey guys help me out here and let me know if I have everything I need to swap to an A4 listed...
4l60E Automatic transmission W/bellhousing
Torque converter w/bolts
Flexplate w/ bolts
Transmission cooler w/lines
4L60E shifter with cables, Park Neutral switch and shiftlock controls
4l60E shift handle
Automatic pedal set
Auto transmission dipstick W/tube
Transmission shift lever
Shifter cable bracket (mounts on transmission pan)
Automatic console top
4l60E transmission crossmember
4l60E Torque arm mount
PNP switch wiring pigtail
Shiftlock control wiring pigtail
Automatic trans wiring harness
Automatic PCM
Now wouldnt the items in bold come with the A4 wiring harness?
Thanks guys.
Flexplate w/ bolts
4l60E shift handle
Automatic pedal set
Automatic PCM
Thanks guys.
Gingervitis Addict
Flexplate w/ bolts
4l60E shift handle
Automatic pedal set
Automatic PCM
Thanks guys.
Flexplate w/ bolts
4l60E shift handle
Automatic pedal set
Automatic PCM
Thanks guys.
