All 700R4s the same?
The wiring harness and plug in the 93 transmission will work only in '93 model cars. Your plug is round and has 5 pins, up until 92 they had square 4-pin connectors. The 94 is 4l60e and will not work. Your unit can be rebuilt, or your valvebody and harness can go into any 700r4. I am certain a forum vendor here can get a 93 unit together for u and u send them the core, otherwise, build the unit u have
LS1Tech Sponsor
Yes you have to bear in mind that shipping alone will be in the 125-150 range. There is just no way to do it for a rebuilt at least not decently rebuilt. Maybe someone local could do a good stock built on your for that. I would say at best online you might get a used one for that maybe but good used 700r4 is hard they have not been made since 93
__________________
WOW...so i think i found the reason why trans aint shifting right.
So there is a short 2" rod that is supposed to be in my valve body/transmission when i did my shift kit couple days ago.
Where does this go? Need a picture of it?
EDIT: forget the picture, i lost the damn thing. Where might it have gone and can i buy it somewhere?
LS1Tech Sponsor
Check out the levels and builds on our website www.performabuilt.com the prices are there also.
As for the part you mention I have no idea without either seeing it or where it goes. May be the 4th accum pin which if missing would cause some strange things 2ND gear starts. 4 gear in 3rd. Bind up in D3 in 3rd gear. Bind up in manual low 1
__________________
