TH350 to LS1 question
just order a SFI approved Flexplate from TCI..... here is the part number.... 890-399753...$214, it has bolt holes for the TH350 converter as well as the TH400 converter.... and is actually the same for the 4l60e's as well. just make sure the convertor you go with has an extension to fit into the rear of the crank....
