Trans choice for 67 Chevy II Swap - 4L60 or 80E?
Hey guys/gals,
I'm in the process of acquiring a LSX based motor/trans for my 67 chevy II and I think I'm set on going the auto route at the moment. My question is should I go with the 4L60 or 4L80E transmission? Given the light weight of the car, I was thinking I should be ok with a 4L60. However, if I can get away with running a close to stock 4L80 I would be fine with that as well. I'll likely be running a stock bottom end with LS6 heads and a "street" sized cam, heh. Nitrous is a strong possibility as well. I'm trying to stay somewhat budget minded as all of these mods ad up!
Here are some details on the car:
Currently running a TH350 w/ 3500 stall
9" rear narrowed - may swap for a 12 bolt
Checkered racing front clip
Fiberglass fenders and hood
Car at the moment is full tubbed - the trans tunnel has been modified so I've got LOTS of room to work with
Thanks for your help/recommendations!
Andrew
Andrew
