Is my 4L60E dead?
Is my 4L60E dead?
Ok, back story on the car. Frame and I'm assuming original trans have 123k miles on it. For the last 20k I have been running a 3500 stall on it with of course a trans fluid cooler. No problems, has been running great for 3 years. Well tonight it decided to say **** I'm out. I have driven the car like it is supposed to be since the day I bought it at 86k miles and it has seen its fair share of abuse, but no real issues.
Now for the breaking part. Was driving along from a stoplight, car shifts into second fine (3500RPM shift) then all of a sudden no drivetrain, just RPMs. No pop, smoke, leaking or anything. Car wasn't even being driven that hard. Pull over, take a look under the car and drive shaft isn't even turning while in gear (friend with me in seat) so I ruled out a gear/rear end issue. Checked the fluid and it was almost dry, but I hadn't been seeing any leaks whatsoever in the driveway where she sits. To be honest it really just feels like the trans isn't engaging into gear when shifted to R or 1,2,D, or OD. It feels as if it tries to but nothing happens. It is now sitting in my driveway after being towed.
I am hoping to get a better understanding of just how bad it may be from you all. I am hoping for something breaking in the linkage between the engine and trans but afraid it may be a converter or whole trans issue. My options are towing it to a shop here in town to have it looked at, a shop 60 miles away that did my converter install (good guy/friend) and have it rebuilt stock, or take it to the shop where I had the dyno tune done since they build stage 3/4 etc transmissions (200 miles).
Thanks in advance for responses and I will try to answer any questions regarding the problem ASAP.
EDIT: Also, no codes are being thrown...
Forward clutches like fluid. Get pissed without it. Then they go postal and take everyone with them. Sorry bout your luck bro. Don't worry about, just fix it and get it back on the road!! Just remember to keep a check on your fluid next time ..........this is a silly question but I have to ask, did you try adding fluid?
