tcc engage
Old 08-11-2009, 08:39 PM
randall 32's Avatar
Default tcc engage
i have a 96 240sx with a 04 gto ls1 & 4l60e. the tcc locks in and out at 38 to 40 cruise speed. i would like to install a sw. to open the circuit. do i sw. tcc solenoid en. or tcc pwm. and will this set a code on the pcm thanks.
Old 08-11-2009, 08:43 PM
LS1Tech Sponsor
performabuilt's Avatar
You would want it in the TCC ENABLE TAN/BLACK and yes it will set a code for TCC electrical
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 08-11-2009, 08:46 PM
randall 32's Avatar
thanks, is there any way to get around setting codes
Old 08-11-2009, 11:56 PM
Moderator
jimmyblue's Avatar
I think you want to scan it and see if it's cycling
because of misfires, or just wants more lock / unlock
hysteresis so it doesn't bug. The electronic she don'
like-a when you cut da wire.
