b&m shift improver kit install need help!
Hey all I bought the b&m improver kit and have everything tore down. I have the pressure regulator put back together with the new green spring and ready to go but I am having a very hard time pulling the 1-2 piston down from the accumulator!! I got the accumulator pin and the 3-4 piston out just fine but the 1-2 piston is stuck tight and wont budge. Anyone run into this problem or is there a trick to getting it out?? I need to remove it to slide two spacers up in between the piston and the housing!!
2001 Firebird Formula automatic
