Nitrous with 4k stall
it depends on what the STR of the converter is how it will respond to the nitrous. but if you dont go over a 150 shot it shouldnt blow thro too bad. you need to talk to the converter manf. and tell them everything about your combo and your goals. they will set you straight on what will work best for an intended purpose and get you real close...
well, not all 4k stalls are going to be created equal. you can have the same stall rating with a different STR and the converter act completely different. you can get a 4k converter to work well with nitrous, it just depends on your total setup. weight/gears/tire/rpm range/engine tq.... i dont see a problem if your not going over 150 but in the bigger shots most stay under that stall speed unless they plan to turn some serious rpms...
A loose converter such as Vig I would worry about maybe more than a true 4000 converter.
A 150 or lower and you should be fine.. 175+ is when you should have to start worrying about blowing through it.
But hell, what do I know.. I'm just an idiot.
FWIW, (not that it matters) both of our cars are DD street cars..
100 shot thru my 4000 stalled added 80 rwhp. so it may blow thru some, but not enough to matter. do a 150 shot. yes, more will probably blow thru, but will have more hp added. this is just what i think now. i'm not a stall or nitrous expert.
I am going next weekend to try a 175 shot with my 4000 PTC 2.4 STR.. I have a good friend that ran a 200 shot on his Ms4/4000 car for many many passes and it didn't blow through his converter.
I will let you know.
I think it is going to be fine, or at least I hope.. If everything pans out I hope to run some 6.7-6.8s spraying at the end of the 60', but who knows.. If I had tires that could hold a shot out of the hole I would hope for some mid 6's, that will have to wait till next year though.
I never said anything was wrong with I just said I hadnt seen or heard of it. Im in to see what happens also. Most guys running street strip nitrous setups run 3600s. But it would definately help you for motor runs if you could run a 4000 and still have success spraying.
I gained quite a bit spraying 175 thru a SS4K Yank. Only problem was I was on the limiter 50ft before the finish. My limiter is set at 7K so it was def. blowing thru it.
