differnce between 4l60e and a 4l60 transmission
Old 11-06-2009, 06:42 PM
winxx2's Avatar
Default differnce between 4l60e and a 4l60 transmission
i have a 97 suburban transmission went out bought one out of a 97 tahoe transmission whats the differnce between 4l60 and a 4l60e trans and will they bolt up and electrical work
Old 11-06-2009, 07:30 PM
LT1WS6's Avatar
4L60E is electronically controlled, it uses solenoids to shift.. A 4L60 is just an upgrades version of the 700r4... they will not interchange what so ever
Old 11-06-2009, 08:36 PM
Bo185's Avatar
GM changed the name of the transmission in the early 90's the 700R became the 4l60 later when it went electronic it became the 4l60e 4speed, Longitudinally mounted,6000#'s rating Electronic controlled.
Later in the earliy 2000's GM dropped the e on everything since everything is now electrical now anyway 4l65,4l70 4l80 6l80/90 etc.
Old 11-06-2009, 10:23 PM
LS1Tech Sponsor
performabuilt's Avatar
"97 suburban transmission went out bought one out of a 97 tahoe transmission"
These two vehicles would have the same trans both would be the 4l60E and will swap even as long as both are 2wd
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Quick Reply: differnce between 4l60e and a 4l60 transmission
