What others will work?????????
Old 11-22-2009, 12:24 AM
mjxlange's Avatar
Default What others will work?????????
Are there any other cars that I can get a transmission out of for a 99 C5. I can get a good one from a firebird for 150$ What all will need to be changed over ect. I would just rebuild mine but the case is damaged
Thanks Mike
Old 11-22-2009, 06:08 AM
FLT
FLT's Avatar
Sorry Mike that will not work. The C5 uses a unique 4l60e transmission case because in your vehicle the transmission is bolted directly to the differential housing. Also for your vehicle in input shaft and stator are different from the F-body trans you have mentioned. In the picture below you can see the seal and the different bolt pattern.
