Any way to make this happen...?
Old 11-27-2009, 06:29 PM
99FormulaM6's Avatar
Default Any way to make this happen...?
I bought my first stalled car last weekend and have a question..
When going through parking lots, driving down roads with low speed limits, the car basically idles. However, with LTs and dumped TDs, there is alot of drone/resonance when it does that. Is it possible to keep the trans in gear to keep it from doing that.
In a t56 car, I could just leave the car in 2nd gear and do like 20 mph and when I let off the gas, the car is still in gear. However, in the A4 car, when I let off the car, the trans shifts and the car is basically idling..
Old 11-27-2009, 06:31 PM
Chrome355z's Avatar
Pull it down into 2nd?
I cruise around town in D. I don't go into OD until i'm hitting long stretches of 45mph +.
Old 12-07-2009, 03:57 PM
'02TA's Avatar
In an A4 car when u put it in 2nd it stays in second and won't upshift or downshift unless u manually do it. This is really the only way to solve your problem.
Old 12-08-2009, 11:05 PM
98 4X4 burban's Avatar
the dumps are causing alot of the drone. put some tail pipes on it
Old 12-09-2009, 07:09 AM
I know the TDs cause alot of the drone, I have had them on multiple cars. But the drone is alot different at 900rpm basically idling compared to 1500 rpm while driving
