Th400 and new rear end
So i am putting in a th400 and have a brand new 9" rear end. It doesnt have the reluctor wheels on the axles. How can i hook up my speedo?
i dont know who makes it but i heared some wehere there is a module that will convert a cable output drive on a 350/400 to a speed sensor.
i also think the speed sensor for the abs in the front hubs can also be used but i dont know how it will effect the abs.
your wire harness should have a sensor that plugs into your vss... since you don't have that this is what your gonna have to do...only down fall is your going to lose abs...
take your driver side front abs sensor and splice that wire into the sensor mentioned earlier, simple as that. takes 5 mins
