4l60e problem with pictures
the other night my car (95 trans am)a4 started making a crazy noise. when i got home and looked under the car i saw these holes. anyone know what might be the problem or what could have happened? btw i do not know much of anything about transmissions any help would be appreciated
If it did, hopefully you can get it fixed before you do any damage. If a bolt came out it could cause the converter to wobble and demolish the pump rotor. It happened to me after the car sounded like i put a handful of nuts and bolts in a blender.
Fix it quick and it won't be that bad.
took off the cover it was a loose bolt that holds the convertor to the flywheel. i put a new bolt in and everything seems good except the starter is missing a chunk out of it
I had a similar issue with my 94 Formula... Except it was a small bolt at the top of the engine in the transmission and converter area. I think it was a little 10 mm bolt that held in the rear seal or something ( I can't remember what it was honestly; It's been 3 years ago) But I pulled the cover and a little bolt that had broke in half fell out. It ended up dragging the face of the converter and the case of the trans on the inside. It didn't hurt anything, but just dug into the case and converter a little bit. Thank God!
Glad you got it figured out. As for the leak, Looks like an oil pan gasket leak and could also be the front crank hub seal. Mine leaked VERY bad and eventually had to replace it! Oil would run out from the crankshaft hub and down the sides and bottom of my pan and all over the exhaust.
But I fixed that FAST lol.
Also had a front pump go bad in my Formula and it leaked trans fluid at WOT, and unfortionentely I was almost always at WOT with that car hahaha.
Glad it was an easy fix!
James
James
