Turbo 400 Flywheel
Old 03-05-2010, 06:02 PM
Biggsw784's Avatar
Default Turbo 400 Flywheel
I am building a WS6 with a 408 and turbo 400 tranny and curious what flywheel do I need to run with this set up??? Thanks for any help.
Old 03-05-2010, 06:30 PM
theguyulove2hate's Avatar
It depends how you want to do it. You can get a converter that is made to bolt up to the ls1 flywheel or Hughes performance and I believe TCI make a flex plate that will bolt up to the ls motor and a gen 1 converter
Old 03-05-2010, 06:50 PM
Biggsw784's Avatar
oh ok. thanks man
Old 03-06-2010, 03:44 PM
209ryder's Avatar
yes the tci one is 399753 and you should buy a special converter that is a ls1/th400 swap ao u dont have to use the spacer and the regular ls1 flexplate will work perfect.Its what i did in my swap
Old 03-06-2010, 11:49 PM
dnkynrbk's Avatar
Use the tci one thats what I used on my build and you dont have to use a spacer and its a hole lot easier. I got mine from a sponsor on here or summit or jegs has them. its the $200 one thats sfi approved.
Old 03-08-2010, 01:03 PM
Man-Crush Warning
01sscam's Avatar
I got mine through FTI.
Quick Reply: Turbo 400 Flywheel
