4L60E Leak
Old 03-15-2010, 08:46 AM
SilverV6Camaro's Avatar
Default 4L60E Leak
My 98 TA was stored for winter and not run for 4 months. The entire time I noticed no leaks, but when I took it out this weekend there was a wet spot of trans fluid under the car. It must have started recently while sitting. Only the front 1/3 of the pan is wet with a couple of drips on it. When the car was running, nothing leaked, so I took it for a drive, and I saw no drips afterward or while it was still running. However after sitting all night, it leaked a little more overnight leaving a small spot on the floor and a couple more drips on the front edge of the pan. Any ideas?
Old 03-15-2010, 04:11 PM
After searching I figure it could be 3 things...the pan gasket, the front seal, or the pump gasket/o-rings. Would the front seal or pump seals cause it to leak while running, not just while sitting?
Old 03-18-2010, 09:28 PM
joecar's Avatar
It it leaks only while sitting (engine off) then it might possibly be the fill tube seal... or the pan gasket.
Quick Reply: 4L60E Leak
