6l80e cooling lines.
Old 04-06-2010, 11:49 AM
ss1129's Avatar
Default 6l80e cooling lines.
Does anybody know what type and or size fitting the cooling lines for the 6l80e are at the transmision and at the cooler?
Old 04-07-2010, 05:26 AM
rsz288's Avatar
Transmission is special GM single bolt quick connect flange. QC type fittings also from lines to cooler. Generally.
Old 04-07-2010, 08:09 AM
ss1129's Avatar
So cut the lines and use their fittings. Gotcha.
Old 04-07-2010, 05:12 PM
rsz288's Avatar
Or you can push 3/8 A/T hose over the QC ridges IIRC. i.e. use something like a G8 or maybe Camaro trans pipe set which brings the pipes out alongside the balancer and use rubber A/T hose from there.
Old 04-07-2010, 06:02 PM
ss1129's Avatar
I found out they make 3/8 pipe to -6an fittings. Im going to go that route. I didnt want to cut anything but I want everything as clean as possible too.
Quick Reply: 6l80e cooling lines.
