4l80 swap, have a few questions
I think my DS is to short what do yall think? lol
Also what size and thread count is the nut that goes on the gear selector shaft?
the way i checked mine was when the rear joint is all the way seated (with weight on the rear end, jack it up if you have to) use a sharpie and mark where the seal is touching the yoke. then pull it out and measure from the mark to the end and add whatever is sticking out if its sticking in 1 and 1/2 inches past the seal and you have 5/8 sticking out past the seal you should be fine.
