wont shift out of 1st wot
Old 05-06-2010, 12:28 AM
nathan.carter95's Avatar
Default wont shift out of 1st wot
just got a 99 z28 yesterday. i havent had any problems out of it till i washed it today. after i left the car wash i noticed it didnt want to shift till way late. it got worse, now it wont shift at wot. it just bounces off the rev limiter. is it possible i got something wet (pcm, speed sensor)? any help would be appreciated
Old 05-06-2010, 12:29 AM
btw it has slp headers, exhaust, and a mild cam
Old 05-06-2010, 01:51 AM
ZachJ03's Avatar
I dont have an answer for you, but I have a buddy with a bolt on 00 Mustang GT who's car is doing kind of the same thing. Its kissing the rev limiter before it shifts, mainly in the 1-2 shift. Im curious to find out what it may be as well. Has your car been tuned and shift points raised?
Old 05-06-2010, 12:41 PM
i dont know. it wasnt doing this when i first got it
Old 05-06-2010, 12:45 PM
gonna try a trans service today if i can get to it
Old 05-06-2010, 03:49 PM
1qwkz's Avatar
you need your trans rebuilt, its the 1-2 band out. i had the same probs
Old 05-06-2010, 06:58 PM
looks like a rebuild
Old 05-07-2010, 04:28 PM
1qwkz's Avatar
where are you located at nathan carter? i gotta guy in dfw who can do it and does wonders with the 4l60e for a dam good price! lmk
Old 05-07-2010, 07:08 PM
northeast arkansas... i put the scan tool on it today and it showed a bad circuit in 1-2 shift solenoid. gonna try that tomorrow, or maybe tonight.
Old 08-02-2010, 11:28 AM
msjcake's Avatar
My 98 T/A is doing the some thing. Did you find out what the problem was?
Old 08-02-2010, 09:27 PM
Detroit Gearbox's Avatar
If your problem is Only second-I would suspect a stuck ck ball in a worn out separator plate (quite common on high millage vehicles.)
If you had no 4th either, I would suspect a worn or broken band (anchor end breaks sometimes)
Old 08-02-2010, 11:57 PM
msjcake's Avatar
Yea its just 1st to 2nd after it does shift everthing is fine. Normal driving it wont shift out of 1st until its 3000+ rpm's and at wot it just stays on the rev limiter in 1st.
Old 08-03-2010, 12:36 PM
Bluvette28's Avatar
Im having the same problem 2-3 gear is good its just 1-2 it sucks i cant race till i get money to fix it
Old 08-06-2010, 03:34 AM
00trans_am00's Avatar
So what do u got to do to fix it?
Old 08-11-2010, 08:57 AM
Bluvette28's Avatar
Im buying a rebuild kit from all pro automatics and just beefing up the tranny. putting a stall in and a manual valve body with a slap shifter.
Old 08-11-2010, 09:53 AM
lt1pwr1's Avatar
Based on that info, I wouldn't assume the trans is shot just yet. You probably have a bad 1-2 shift solenoid or the wiring to it is messed up. It really is beneficial to have a scanner that can command the solenoids, then you can check for power at the 1-2 solenoid. If you don't have that option, you can just replace it and see.
My uncle's Silverado was doing the same thing with the 2-3 solenoid and a couple trans shops told him he needed a new trans. Well, my dad put the Tech I (old school truck) and saw there was nothing happening for the 2-3 shift solenoid and replaced it and it's been working fine since.
Quick Reply: wont shift out of 1st wot
